spark plug with oil on it.How bad is it?
Old Feb 7, 2006 | 06:20 PM
  #31
eclipsed4u's Avatar
Default RE: spark plug with oil on it.How bad is it?
ORIGINAL: jeffery0266
Alright,I took the car to a place to talk to a guy about getting a valve job done.He told me that before I jerk the head off it would be a good idea to get a leak down test done.Then I went to talk to another guy about the test,the more he heard he said that it sounded like something in the EGR system.He wants to do a diagnostic test on it before anything is done.Could my problem be in the EGR system or should I find another mechanic???
i don't think a problem with the EGR system would cause you to leak oil in with the spark plugs.
Old Feb 7, 2006 | 06:21 PM
  #32
eclipsed4u's Avatar
ORIGINAL: eclipseonjuice
I bet it is a simple leak in the seal of the valve cover. That is the most logical reason without getting so serious.
he had the valve cover gasket replaced.
Old Feb 7, 2006 | 07:19 PM
  #33
eclipseonjuice's Avatar
Oh sorry missed that part
Old Feb 8, 2006 | 05:37 PM
  #34
jeffery0266's Avatar
I agree about the EGR system not the reason for the oil in the plugs.I got the valve cover gasket replaced a few days ago.I am going to pull a plug and see if the oil is still there.I'll come back and let ya know.
Old Feb 8, 2006 | 07:37 PM
  #35
All right,I checked the plugs and there is no oil on any of them.So,I am assuming the valve cover gasket or the new plug seals worked.I still have the hesitation problem when I pull out from a dead stop.Could it be a bad injector or maybe a bad coil pack?EGR system??
Old Feb 8, 2006 | 08:28 PM
  #36
eclipsed4u's Avatar
you said that there was no oil, but did you check if any were fouled? that could cause the hesitation
Old Feb 8, 2006 | 08:53 PM
  #37
I replaced the plugs and the wires when the valve cover gasket was replaced.It looked like normal wear.
Old Feb 9, 2006 | 09:47 AM
  #38
get435's Avatar
what dose your idle sit at? dose the car hesitate when not in gear?
Old Feb 10, 2006 | 05:02 PM
  #39
brandoN^gsT's Avatar
I'm having the same problem. I changed my plugs, and there were oil on all of them. How much did you pay to change your gaskets, and seals? I have some hesitation too. It feels like there is no pull off the line. My idle is sitting a little low. I have adjusted it, because it was idling too high...Maybe I went too low?
Is changing the gasket just removing the plugs/wires, and valve cover? Is it jsut under there? Let me know, thanks.
-brandoN^-
EDIT// Oh, also, my car does hesitate when not in gear, it gets dow, sometimes to 400, and moves slightly, and the car slightly sputters.
Old Feb 10, 2006 | 05:46 PM
  #40
eclipse27's Avatar
My car is doing the exact same thing, and i did the same thing you did. Its most likely a bad headgasket. My 95 rs sputters in lower rpms and once it hits around 4 or 5 its fairly smooth sailing. Water comes out the exhaust, and i have had oil in my spark plug chambers. Check the headgasket again if you have not already checked it.
