spark plug with oil on it.How bad is it?
Old Feb 10, 2006 | 05:55 PM
  #41
brandoN^gsT's Avatar
Default RE: spark plug with oil on it.How bad is it?
awesome, I'll do that after work. Thanks Mike.
-brandoN^-
Old Feb 10, 2006 | 08:59 PM
  #42
jeffery0266's Avatar
I don't remember exactly what I payed to have the valve cover gasket replaced cause I was having other work done to the car at the same time.I am pretty confident it's not the head gasket cause I had a compression test done and it held at 155 psi.And yes,my car hesitates in neutral,it seems to be not as bad when it warms up,I was using the cheap gas but today I filled up with the good stuff,the hesitation is still there but it seems like not as bad as before.
Old Feb 12, 2006 | 10:20 AM
  #43
get435's Avatar
have you checked nayhting with the fuel system for the hesitaion? almost sounds like dirty injectors.
Old Feb 12, 2006 | 07:31 PM
  #44
It very well be the injectors.I ran some injector cleaner through it last week but did't tell any difference.If I decide to buy new injectors what should I use?The motor is stock as far as I know,It got a cold air intake on it,I plan on eventually buying a turbo for it but I have a long way to go before that.
newoutlanderfan
Mar 3, 2014 07:02 AM
red123
Oct 5, 2009 12:38 PM
dsmbuilder
Jul 17, 2007 12:33 AM
spyder4g63t
Oct 30, 2006 09:07 PM
workmanls
Jul 23, 2004 04:58 PM
