Sputter when above 5000 RPM
RE: Sputter when above 5000 RPM
if it does have to do with the fuel mixture, you could possibly have an old fuel filter causing it to not get the fuel flow you need, but i think if the fuel filter was bad, it would take a little extra time to start it
Dude it might idle fine.. but when its under boost it can **** up.
Aftermarket spark plugs.... NGK are some of the cheapest out there? Stick with em.
Aftermarket spark plug wires suck *****....
good point sebba, it could idle like a champ at idle, but the thing it when you put the gas to the engine your spark plugs might be off just a liiiittle bit cousing them to not fire correctly.. this well cause access oil on them..
ORIGINAL: nick_200321
teason1978@hotmail.com
08-27-2010 12:39 PM
alopandur
04-27-2009 03:40 AM
