99 eclipse gs idles at 5000 rpm
Old Jul 20, 2009 | 07:41 PM
c_bur's Avatar
Default 99 eclipse gs idles at 5000 rpm
couple days ago i took of my thottle body intake and fuel injector to change them. put everything back on started car up fine but the engine jumps right to 5000rpm and wont budge. any ideas on what might be wrong?
Old Jul 20, 2009 | 07:55 PM
dsm1990gsx's Avatar
Is the throttle cable hung up on something?
Old Jul 20, 2009 | 08:45 PM
c_bur's Avatar
no throttle cable is fine tightened the cable guide in the same place as before
Old Jul 20, 2009 | 08:46 PM
dsm1990gsx's Avatar
Is the throttle plate completely closed?
Old Jul 20, 2009 | 08:49 PM
c_bur's Avatar
yeah and if i pop the throttle the rpm jump up then straight down to about 1000 for a second or two then right back up steady around 4500-5000
Old Jul 20, 2009 | 08:57 PM
dsm1990gsx's Avatar
Can you open the thottle manually? When you let go make sure its closing and not sticking open.
Old Jul 20, 2009 | 09:07 PM
c_bur's Avatar
tried that. the plate opens and closes without any drag. friend said that it might be a vacuum leak but i dont even know where to start with that. maybe i'll just retrace my steps
Old Jul 20, 2009 | 09:17 PM
dsm1990gsx's Avatar
Could be a vacuum leak but that'll usually make the car want to stall.
Old Jul 21, 2009 | 09:06 AM
BISS adjustment?
G-Race
Jan 10, 2012 12:32 AM
newguy2007
Dec 9, 2009 02:38 AM
Wi_Fibre
Oct 17, 2007 03:21 PM
eclipse97eclipse
Sep 9, 2007 10:23 PM
DragonRacerX666
Feb 5, 2007 04:00 AM
