Sputtering while driving
Old Dec 4, 2005 | 02:06 AM
1997gsteclipse's Avatar
Default Sputtering while driving
Ok my car when running at about 2500 rpms sputters and misses real bad 95% of the time. Do yall thanks plugs and wires could help that qreatly or think it might be something else. Also does anyone with a gst know what relay that is mounted strait behind cyl #3 it clicks fast but can only hear it from inside but can just barely hear it from outside. Does it hurt anything Thanks for any help
Old Dec 4, 2005 | 02:24 AM
mtalma's Avatar
Default RE: Sputtering while driving
I just bought a gst 98. Like you the car, sputtered when accelerating. I changed the plugs and gave the car a general tune up and this stopped. Good luck.
Old Dec 4, 2005 | 03:02 AM
DSMTalonAWD51's Avatar
could be the plugs/wires, but they are usually more of a problem at high rpms, not low. If it only sputter when you get on the boost, you may have a boost leak somewhere in your intake piping.
Old Dec 4, 2005 | 01:05 PM
It isn't as bad when i'm accelerating as it is when i hold it at around 2500 rpm (about 55mph). I think that plugs and wires probally have a big part of it but i'm not forsure. What do yall recommend on plug wires NGK of someother brand? Thanks alot
Old Dec 4, 2005 | 04:36 PM
FireDoc's Avatar
Magnacores are also good wires. Definately NGK irridiums for plugs. They burn MUCH hotter than platinum.
Old Dec 4, 2005 | 05:02 PM
for plugs, stay away from iridiums, DSMs love NGK BP7ES or BPR7ES, roadrace sells a set for $10. They also sell a set of magnecor plug wires for $79, which is cheaper than replacing the stock set at the dealer.
Old Dec 8, 2005 | 03:04 PM
FireDoc's Avatar
Interesting. What problems do irridiums cause?
Old Dec 8, 2005 | 03:10 PM
shreff99's Avatar
I had the sputtering problem in my old '97 Spyder GS once...It would only happen under 3000 RPM..Replaced the plugs and wires, problem solved.
96420ars
Nov 17, 2008 04:58 PM
Electech1
Nov 3, 2006 10:29 PM
vr4luver
Feb 24, 2006 01:19 AM
ron Kirk
Jul 31, 2005 01:45 PM
bdunn
Dec 1, 2004 03:38 PM
