srs problem
I figured out what i needed but i'm going to post just for everyone else's information. You can remove the air bags if you take the negative and positive sides of the battery off and make sure they don't touch the terminals. To be safe i took the entire battery out. Once you've done that locate the connectors which are red with a green top lock piece and disconnect them. The driver side connector will be a couple inches behind the steering column cover. On the passenger side the air bag connector will be the same red piece. The connector is located on the left side of the glove box attached to the metal panel that holds the cd player. Once you disconnect both harness connectors the only thing left is to unscrew the bolts and the air bags pop right out.
