SRS light
Old Jan 4, 2006 | 08:58 PM
okcdude72's Avatar
Default SRS light
I just recently took apart my dash board to fix something and put it back together. Everything works fine but the SRS airbag light is on now. I cant remeber if it was before. Is it always sopost to be on? If not what should i do? And if it is, sorry for my stupidity.
Old Jan 5, 2006 | 12:07 AM
Joel_CA's Avatar
Default RE: SRS light
Try unplugging the battery for a few seconds, reconnecting it- then check if the light comes back on. There's a good chance you left something disconnected or possibly even damaged a wire in the SRS circuit during your dash removal procedure. I'm about to remove my dash too to fix my defrost vents. Here's an instructional website you can use to double check your previous repairs. It's got lots of pictures and step by step guides.. Good Luck!
Joel, CA
Old Jan 25, 2006 | 01:27 PM
m3kgt_99's Avatar
Did you unplug your air bag? that is the only reason that something like that would happen... open your glove box and drop the plastic on the dash and look at the red connector at the end of a yellow wire. It is more than likely unplugged
Old Feb 18, 2006 | 09:06 AM
jimweee's Avatar
Check and see if your backup lights fuse is blown. I had my SRS light on and happened across a blown fuse for the backup lights and the light went off. Just somethin to try...........
shum_87
Aug 29, 2009 05:05 AM
pgb205
Jun 4, 2009 10:40 PM
pink_eclipsechic
Mar 29, 2006 10:09 AM
jimweee
Feb 6, 2006 08:27 PM
Mustang
Oct 22, 2005 03:30 PM
