srs problem
Old Aug 15, 2007 | 12:51 AM
dahuckman15's Avatar
Default srs problem
My friend and i are stripping a 98 eclipse gs and were wondering where the air bag wire harness locations were and what they looked like for the driver and passenger air bag. any help is appreciated!
Old Aug 15, 2007 | 10:16 PM
Default RE: srs problem
I figured out what i needed but i'm going to post just for everyone else's information. You can remove the air bags if you take the negative and positive sides of the battery off and make sure they don't touch the terminals. To be safe i took the entire battery out. Once you've done that locate the connectors which are red with a green top lock piece and disconnect them. The driver side connector will be a couple inches behind the steering column cover. On the passenger side the air bag connector will be the same red piece. The connector is located on the left side of the glove box attached to the metal panel that holds the cd player. Once you disconnect both harness connectors the only thing left is to unscrew the bolts and the air bags pop right out.
imtalkintou
Apr 14, 2006 04:17 PM
pink_eclipsechic
Mar 29, 2006 10:09 AM
okcdude72
Feb 18, 2006 09:06 AM
jimweee
Feb 6, 2006 08:27 PM
Mustang
Oct 22, 2005 03:30 PM
