starter hook up
does anyone know which wires go to what on the starter off a 4g63 engine?theres two bolts that wire a connects to...one positive and one negetive...n also is there a way to check if your starter is still good?
http://i236.photobucket.com/albums/f...od/starter.jpg
need to know if that black peice of wire conneted to the bolt is negitive or positive....
if a starter is bad, when you turn the key you will hear the starter click. now if your stuck somewhere you can (lightly) tap the starter and it should start up.
whats up with yours? doing the same thing or just pull it out and forgot which wires go where?
