starter hook up
Old May 13, 2008 | 06:22 PM
clips69's Avatar
Default starter hook up
does anyone know which wires go to what on the starter off a 4g63 engine?theres two bolts that wire a connects to...one positive and one negetive...n also is there a way to check if your starter is still good?
Old May 13, 2008 | 07:35 PM
clips69's Avatar
Default RE: starter hook up
http://i236.photobucket.com/albums/f...od/starter.jpg
need to know if that black peice of wire conneted to the bolt is negitive or positive....
Old May 14, 2008 | 07:57 AM
clips69's Avatar
does anyone at least know how to tell if the starter is out?
Old May 14, 2008 | 08:37 AM
tjbiker031's Avatar
if a starter is bad, when you turn the key you will hear the starter click. now if your stuck somewhere you can (lightly) tap the starter and it should start up.
whats up with yours? doing the same thing or just pull it out and forgot which wires go where?
RCJr9186
Aug 25, 2005 09:59 PM
mitsunoobie
Apr 12, 2005 09:56 AM
mitsunoobie
Mar 15, 2005 08:43 PM
antomx
Dec 9, 2004 07:10 AM
mitsu23
Nov 2, 2003 07:19 PM
