Starter removal/installation
Old Nov 18, 2004 | 10:35 AM
cptkid570's Avatar
Default Starter removal/installation
Oh my goodness. I took a good look at my 1997 eclipse, 2.4 liter, non-turbo engine last night. What's with the position of the starter? I have absolutely no idea how I am going to get this thing out and back in. It's on the top, back side of the engine.
Does anyone have any helpful hits on how to get remove and install a starter on this? Looks really hard to get to even with the air intake removed. Do I have to remove the intake manifold?
Old Nov 18, 2004 | 11:39 AM
Dans Talon's Avatar
Default RE: Starter removal/installation
I don't have experience with this model but is sholud be do-able eh?
With the car on jackstands or ramps and the battery disconnected, the starter should be accessable from underneath.
You may disconnect the exhaust pipe from the manifold and drop the exhaust, then you should find enough room to turn a wrench and then also drop the starter out the bottom of the car ?
DT
Old Nov 18, 2004 | 03:58 PM
cptkid570's Avatar
Looks like there is a driveshaft in the way still.
Old Nov 19, 2004 | 09:47 AM
Dans Talon's Avatar
My Mitsubishi Eclipse Chliton's Book lists from 1990 to 1998.
So I looked up "Starter, removal and installation"
It gives one line which says:
"For 1995-98 2.4L engines, remove the air cleaner and air intake hose."
Thats all it gives. Thats official.
DT
Old Nov 19, 2004 | 12:48 PM
cptkid570's Avatar
hahaha - nice description. Should say "remove the air cleaner & air intake hose -- and then you might be able to see the starter you sucker!" hahaha
Old Dec 20, 2004 | 03:10 PM
justin0469's Avatar
well if ur still tryin to get it out, on my gst i just got underneath and just wiggled it around the exhaust and whatever else, just gotta pull hard to get it thru the exhaust.
Old Dec 20, 2004 | 08:36 PM
DrAgOnBoY45479's Avatar
too bad you dont have a 2.0 non-turbo... thats gotta be the easiest starter to get to i have ever seen... 2 bolts right in front of the engine and out she comes... probably a 15 min. job -mumbles- its still sucks not having a turbo tho -mumbles-
Old Dec 23, 2004 | 03:47 AM
way2slo's Avatar
ORIGINAL: DrAgOnBoY45479
yeah, and with air tools...hey, could I have my starter go out? I'll trade one of my other probs...
(next time i get in, i bet it wont start or something worse will happen)
mlahrens
Jan 29, 2016 06:54 AM
thumper_64735
Jul 15, 2009 01:33 PM
thumper_64735
Jul 12, 2009 06:38 AM
Gstfat
Nov 26, 2007 07:14 PM
cptkid570
Nov 29, 2004 10:49 AM
