Starting Question
Old Feb 17, 2007 | 05:07 PM
96eclipsedohc's Avatar
Default Starting Question
ok well in the mornings it takes about 7 or 8 tries to get it to start, and when it does start i have to manually keep it going, it takes about 5 minutes before it will even idle.. ok well even after it gets warm i try to start it, it starts the check engine light comes on, then it idles very wierd in the 200 rpm-1000 rpm marks, then the battery light comes on then it idles fine... please someone help me, i already changed the idle air control valve/sensor.. but what about the throttle position sensor???
Old Feb 17, 2007 | 05:36 PM
I Drive Naked's Avatar
Default RE: Starting Question
Well if you have a battery light come on, you can narrow that down to 2 things.
A. Battery
B. Alternator.
Check you battery and alternator.
An alternator reading over 13volts indicates a good alt.
Anything under, replace it.
And next time, doa search on this topic, it was discussed about a week ago.
Old Feb 17, 2007 | 07:07 PM
go and get the check engine light scanned
krucz36
Aug 23, 2014 06:48 AM
firefighter164
Nov 28, 2011 06:47 PM
xp8ntballkid309x
Dec 26, 2007 06:57 PM
xp8ntballkid309x
Dec 26, 2007 01:19 PM
stealth1
Jul 29, 2005 10:00 PM
