Sticking Caliper, cannot fix!
Old Dec 26, 2013 | 07:45 PM
SKHafford's Avatar
Default Sticking Caliper, cannot fix!
Hello everyone. I've been battling this caliper for over a month now, and I'm stumped at what is going on. The front passenger caliper sticks everytime I take the car out for a drive. First sign was the back passenger, front driver and front passenger all sticking at different times. Those were changed also.
I have changed the caliper 4 times on passenger side(within a month), the hose 2 times(within a month), and a new master cylinder about a month ago. Everything seemed fine until my wife and I changed our brake pads before driving from NC to FL about 3 weeks ago.
We made it maybe 10miles before the caliper started sticking again! But we drove anyway, taking the tire off every time and c-clamping the caliper back open every time it stuck. While in FL we replaced the caliper, again, and drove it for 2 days and everything seemed well. On the way back home a week later, the caliper started sticking again. I noticed that if I cracked the bleeder the caliper would unstick, so that made our drive home a bit better. Since we suspected a pressure issue, again, we replaced the brake hose when we got back to NC. And of course, the caliper still sticks.
I literally cannot think of anything that would cause this one caliper to keep sticking no matter what.
Is it possible there is a clog somewhere? Is the metal line that hose connects to kinked(possible?)?
Don't know much about cars but I'm up for anything, and running out of money .
Thanks.
-Sean
I'd like to add that when installing the brake hose, I may of twisted it a bit much. I started at the metal hose fitting, and hard to force twist it to the caliper, kind of hard, maybe I kinked it?
Old Dec 27, 2013 | 01:27 AM
Akzle's Avatar
kinked hose would be fairly obvious.
Sounds like brakes are dragging. Adjust pedal height and freeplay to spec in workshop manual.
Old Dec 31, 2013 | 02:52 PM
SKHafford's Avatar
Is it possible it could be a bad proportional valve?
Old Dec 31, 2013 | 05:49 PM
SKHafford's Avatar
The left caliper is starting to stick now too, I'm at a loss.
Old Dec 31, 2013 | 07:49 PM
mxmikie's Avatar
have the brakes pressure bled
Old Jan 1, 2014 | 12:31 PM
SKHafford's Avatar
before i spend the money on pressure bleeding? What would it fix?
Old Jan 1, 2014 | 09:48 PM
Akzle's Avatar
it's not a hard job. have a friend pump the brake pedal, you watch the maser cylinder and make sure it's topped up with fluid, attach a hose to the bleed screws, hold the end in a jar of brake fluid. once pressure is developed, crack the screws.
SKHafford
Mar 10, 2014 12:06 AM
mtc137
Sep 26, 2009 05:24 PM
pgram
Sep 20, 2009 10:39 AM
melsa1
Dec 3, 2008 01:42 PM
mikeinfhaz
May 26, 2006 12:24 AM
