Thinking ahead. TUNING!
Old Feb 20, 2007 | 05:25 PM
agallardo's Avatar
Default RE: Thinking ahead. TUNING!
Alright, so tuning wise, you guys recommend the dsmlink? Well, i am tight on money, so why is it bad with the safc, wideband, and logger? (maybe chip) That setup is cheaper, isnt it?
Old Feb 20, 2007 | 06:01 PM
pats90gsx's Avatar
ORIGINAL: RCJr9186
for a maxed out evo 16g 550's are borderline so 650's will most definatly do the trick and you'll be able to make it as rich as you want.
Why in the hell would you want to make it rich? You would not want to make the car run rich, that would kill your performance.
Alex, that setup will work, but tuning with DSMlink cannot be beaten (unless you go to AEM EMS). Its just so easy. You can compensate for whatever injectors you want, its got the stutterbox and NLTS, and ****loads of other cool features that are very user friendly. You can also get the best tune for your car with link. One of the local guys dynoed with his safc2 seutp, then dynoed with link. On the exact same setup he dynoed 20hp more with dsmlink because he could get a more optimum tune.
Old Feb 21, 2007 | 05:25 AM
racerx55's Avatar
You sure as hell dont wanna run a turbo engine lean! duh.
11:1 a/f at WOT, no leaner than that. some guys run even more fuel. I prefer to lose a little performance over trashing my engine.
Lean makes power but also causes mega detonation and melts **** when your boosting.
Old Feb 21, 2007 | 10:15 AM
RCJr9186's Avatar
thank you racerx
Engineer... thanks for the confidence boost buddy!! lol
Old Feb 21, 2007 | 10:43 AM
ORIGINAL: racerx55
deending on the gas your running and turbo yur running you could go slightly leaner than a ratioof11.1, I tune my car to 11.3-11.4 with the SAFC and its on a TC big 16G stock evo turbo and 93 pump with no problems.
The Problem with the SAFC is when you tune you can only change the MAS readings and it basically tricks the ECU to running rich. the poblem is it pulls timing and your AFR if you where to dyno would prob not be a nice straight even line because your only correcting RPM increments of 200RPMs if that most people dont even do that much its usually like 1000 RPM increments. basially between the un even AFR and pulling timing that would get you at least the 20WHP that was stated earlier as a gian between the SAFC and DSMlink
Old Feb 21, 2007 | 10:49 AM
RCJr9186's Avatar
bingo... basically... GO with the DSMLink, it will keep you from knocking your engine and is much more in depth, a brand new SAFCII is about 250-275 last time i checked, a brand new dsm link program and eprom is about 550 and you can someitmes find them used on ebay or a forum for between 350 and 450... basically a $200 difference for 20whp... that's only $10/hp which is extremely cheap!
Old Feb 21, 2007 | 11:30 AM
well not to mention your running alot safer that way also. But if you decided you didnt want to use dsmlink, or you dont have the laptop to do it. Then getting DSMchip, and then fine tuning with the AFC will work fine
Old Feb 21, 2007 | 11:49 AM
racerx55's Avatar
My GSX i have to keep it 10.6 or so but it burns a little oil, which also adds to detonation,plus its just a pice of ****
My talon with the 20g im able to get it to 11.3 before i get any knock, but i keep it at 11.0 on the nose for safe measure
Read my post about what it takes to kill a 7 bolt if your wondering what lean will do to a turbo motor.. i burnt a hole through the turbine housing on that one
Old Feb 21, 2007 | 02:37 PM
agallardo's Avatar
Well, this is the plan... HOPEFULLY! A budy of mine (pats90gsx) is going to sell me his SAFC II, logger, and DSMchip for $400. What do you guys think of that deal?
Old Feb 21, 2007 | 04:47 PM
well what stage chip is it, cuz thats important. But assuming its a stage 3 and also it must be programed for your specific mods already. Heres the prices (basically new)
DSMchip = $140
SAFC = $250
Pocket Logger = $200 (depending on what type i guess it could be more)
so total about $590. So that seems like a pretty good deal to me
