Throttle body difference
Old Jun 29, 2006 | 05:48 PM
Nubiebubie_GSX's Avatar
Default RE: Throttle body difference
Well that kinda suck lol if there is a leak. It happen after replacing throttle body. The throttle body came with another tps and ISC which i used. The other thing i did was run the VAC lines for the EGR. Its not hooked up to the solenoid yet though. Acceleration fine its just if i try to hold the rpm steady say like in idle it kinda drop a few hundred then goes back up.
Old Jun 30, 2006 | 03:05 AM
98MitsGSX's Avatar
Dude, you need your EGR valve hooked up...I think that's why your rpm's are searching...
Old Jun 30, 2006 | 10:53 PM
98MITsGSX you 100 percent sure.. because if soo ill hook it up. The car didn't do this before and it was all disconnected. Also there are ppl who disconnect there egr and evap system and haven't complained about this over at dsmtuner. But if your 100 percent sure ill go buy some more vac hoses and try it out.
Old Jul 1, 2006 | 02:43 AM
98MitsGSX's Avatar
If a car has EGR, it has it for a purpose....you need that to run properly...I am sure, I even talked to my father about it...he said the same thing. You need EGR to keep backpressure regulated...blah, blah, blah. He said hook it back up and you'll like the result...I dunno, I usually listen to my old man.
et2sub
Apr 22, 2005 09:37 PM
1398spdr
Mar 19, 2005 05:12 AM
magno_313
Jan 16, 2005 04:15 PM
Davet2
Nov 18, 2004 01:17 PM
JimmyB
Jun 11, 2004 07:52 PM
