Tial BOV or Wastegate??
Old May 12, 2005 | 01:31 AM
matt02708's Avatar
Default Tial BOV or Wastegate??
I'm looking to get a Tial Blow off valve. I was wondering whats the difference between a BOV and a Wastegate. Will I need a new upper IC pipe for the new BOV and how will i know which size??
Old May 12, 2005 | 10:52 AM
patsevo8's Avatar
Default RE: Tial BOV or Wastegate??
BOV releases the pressure (boost) in the intake pipes. The wastegate releases pressure in the turbo itself.
You shouldn't have to get a new upper IC pipe and BOV don't come in sizes really.
Old May 13, 2005 | 01:55 AM
matt02708's Avatar
Which is better? Wastegate or BOV?
Old May 13, 2005 | 02:15 AM
crunchie's Avatar
ORIGINAL: matt02708
They do different things. You're comparing apples and constipated rhinos here.
The wastegate releases excess boost so you don't blow your engine. The BOV prevents turbulence/backflow when your TB closes so you don't wreck your turbine. If you really want to spend some cash, go get yourself a SAFC or turbo timer. More fun with the blinky lights.
Old May 13, 2005 | 04:49 AM
DSMTalonAWD51's Avatar
u dont buy a wastegate unles you get a big turbo, by then you wil know what it is. You can get a better bov because the stock one will leak and prevent you from raising the boost. When you get a new bov get an upper ic pipe too because thet stock one is very restrictive.
Old May 13, 2005 | 02:18 PM
matt02708's Avatar
Any Suggestions on what brand of IC pipe?? Do you know what eclipse PSI is at stock?? what is it around 6-9?
Old May 14, 2005 | 01:07 AM
patsevo8's Avatar
You should actually be safe around 13-15lbs. Any and all brands of upper IC pipes are good because they are all less restrictive than stock.
newguy2007
Dec 2, 2007 11:21 PM
jerusry
Nov 22, 2007 12:06 PM
RCJr9186
Jun 12, 2007 02:29 PM
93eclipsegsx
Feb 27, 2007 12:44 AM
