timing
timing
I decided to change the timing belt and now everything is screwed. I dont know how to time it so I can get everything back working again. I need help to get my car back. I have a manual but I find it confusing can some one help me out. everything is apart right now.
also I started to take the balancing belt off, found out it looked brand new. so I had it partially off, and then just put it back on. What is the sensor on the balancing belt, is it alright I touched, moved it around and then put it back on. how do align that too.
SOMEONE HELP
SOMEONE HELP
RE: timing
I have a 97 GSX. And I have the the engine running and I'm sure its running well. There is alot of noise coming from under the car around 4k RPM(I think its and exaust leak). Im going to check it out today.
Can you time this car with a timing light.if so how, I have a timing light.
judien
03-09-2018 03:41 PM
