Timing
I am trying to replace the timing belts on a 92 Eclipse 1.8. Everything is taken apart to get the belt off, but it will not slip past the lower pulley. I have taken the two oil pan bolts hoping that would do it. If anyone has diagrams I would really appreciate it. I guess I have to take the lower pulley off. Already took the belt off and see no way of keeping it from spinning unless I put the B belt back on. Let me know.</P>
ss1cgc@hamptonroads.com</P>
<IMG src=smileys/smiley16.gif border="0"> Hey ss1cgc, I don't think you have to take off the lower pulley to take off either the main timing belt or the 'B' belt, you probably just have to loosen center bolt on B timing belt tensioner pulley.This pulley should be on an eccentric shaft that is turned to tighten belt for proper tension. Once bolt is removed you should be able to remove pulley and then the B belt. I could be wrong, but I will check my documents for the 1.8 engine and get back to you later.I had the timing belt replacement procedure for 1.8 on e-mail file but I deleted it, so let me look into it. Randy
<IMG src=smileys/smiley4.gif border="0">Hi ss1cgc, I sent you all neccessary instructions for timing belt(s) replacement for the 1.8 liter engine. It was sent to your e-mail address and is from "The Buffalo Skill Center". Good luck, let me know if you need any more help, Randy
hi randy, i need your help one more time.</P>
i set all the pulleys marks up, I put the screwdriverin the hole itwent in about 2 inches, like in the pictures you sent me, but the engine shakes pretty bad, if I rev the engine sounds like poff poff poff,do you think i didn't do it right?</P>
is there any way to know if the timin belt is ok, or could be other thing.</P>
thank you Randy.</P>
hello my name is mike i have a 94 eclipse gs and i recently did a timing belt on it and when i started it up it ran fine then all of the sunnden it started running on 2 cylinders but whe i checked its only getting spark from 2 cylinders i was told that the cams are out of timing is this true and if so what do i do to fix that thanks
judien
03-09-2018 03:41 PM
