timing belt
Old Nov 2, 2007 | 04:13 PM
98gstspy's Avatar
Default timing belt
ok i am changing my head gasket and timing belt should i get a timing belt kit (tensinor included) or just the timing belt where there isnt a new tensinor with it
Old Nov 2, 2007 | 04:16 PM
dorian7's Avatar
Default RE: timing belt
Well it depends on how many miles are on your car, but I would go ahead and do it. Do the balencer belt to while you are in there if the kit doesn't come with it. Paying a few extra dollars for the kit is better than having to take it all the way back apart later to fix something. When I did it I just replaced the water pump too.
Old Nov 2, 2007 | 04:45 PM
98gstspy's Avatar
ive got 130805 miles on it u think i should do the water pump to
Old Nov 2, 2007 | 06:21 PM
bestwiseguy's Avatar
It would be a good idea yes. Might as well do it all at once so you dont have to worry about it later.
Old Nov 2, 2007 | 07:53 PM
i agree with them. Whe doing the timing belt its always a good idea to do the tensioner and water pump as well, otherwise if they end up going you have to do it all over again, and in the case of the tensioner going youll end up needing to rebuild the head. Better safe than sorry
Old Nov 2, 2007 | 08:04 PM
dsm1990gsx's Avatar
Its always a good idea to do the timing belt, tensioner, pulleys, h20 pump and b/s eliminator since you dont know when it was last done. Fix it right the first time.
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
