timing belt
Old Dec 7, 2007 | 05:51 PM
98gstspy's Avatar
Default timing belt
i just did mine timing belt and now my car only idels about 100 rpms could this be beacuse i have the timing of one notch because when i changed it it looked like there were to marks on the crank shaft. i have all of the marks at tdc except for the crank i am just guessing that the big notch is the tdc mark anybody know what i am talking about
o and a picture of what that mark might look like if anybodys got it
Old Dec 7, 2007 | 06:47 PM
dsm1990gsx's Avatar
Default RE: timing belt
If you go to vfaq.com they have a complete wirte up w/ pics. If the timing is off 1 tooth you'll have a rough idle.
Old Dec 7, 2007 | 07:04 PM
98gstspy's Avatar
so if i change it would that fix the problem
Old Dec 7, 2007 | 07:12 PM
dorian7's Avatar
It sounds like your timing is off, I would reccomend checking all of your timing marks (CAMs, crank, balance shaft) if you only did your timing belt then that Has to be the problem
Old Dec 7, 2007 | 07:29 PM
dsm1990gsx's Avatar
ORIGINAL: dorian7
I agree, double check eveything and if you can post pics of the timing marks.
Old Dec 7, 2007 | 07:50 PM
TheAdvocate's Avatar
With the crank, its actually on that metal plate behind the gear..
Old Dec 7, 2007 | 09:08 PM
98gstspy's Avatar
well when i did it my head gasket was leaking so i figured while i was there i would replace the timing belt water pump and balence shaft belt( which was actually all f'ed up in there) i know the head gasket isnt leaking so if it was off on mark that would cause it to run at low rpms. i know when i set it up the cams, bal saf, and oil was all lined up perfectaly but the crank i couldnt figure out.
Old Dec 7, 2007 | 10:59 PM
dorian7's Avatar
I would most definently not run the car ANYMORE if you have no idea where the balence shaft is in terms of timing. Look on that Vfaq page and pick up a repair manual at the auto parts store. All of the timings HAVE to be perfect.
Old Dec 8, 2007 | 04:21 PM
dsm1990gsx's Avatar
Can you post pics of the timing marks on the timing belt and balance shaft belt? You probably have the b/s off. And just like dorian7 said checkvfaq.com and make sure you have the b/s timed right and not off 180*.
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
