timing belt!!!! help
Old Sep 30, 2006 | 08:06 PM
2nd g eclipse gst's Avatar
Default timing belt!!!! help
ok guys i really need some help, i borrowed my moms pt cruiser yesterday and i was on the interstate when all of a sudden the pt dies so i pulled over to the side of the road and realized my timing belt was gone is there any chance of this bending any valves ???? its a 2001 pt cruiser 2.4 motor automatic any help is greatly appreciated!!!!
Old Sep 30, 2006 | 08:20 PM
93eclipsegsx's Avatar
Default RE: timing belt!!!! help
id assum you bent from half to al of them. it should still be under warrenty so i would call the dealer. ASAP
Old Sep 30, 2006 | 08:22 PM
well we barley bought the pt and it didnt come with a warranty.....so well be coughin out da bucks any idea how much this is gonna cost??? i bought da belt already it was only 30 bucks
Old Sep 30, 2006 | 08:27 PM
well your gonna have to take the head off and see what you find. how many miles are on the car?
Old Sep 30, 2006 | 08:29 PM
89,***, i had a friend tell me something bout a zero head tolerance and that might have saved the valves have you heard of this???
Old Sep 30, 2006 | 08:42 PM
well with the mileage, id get a new water pump. and other things that you need to do with a timing belt change. well i think most new cars have a no tolerance motor so if you do jump or snap a timing belt. you will need to get the head rebuilt. depends on how much its gonna cost depending how much is bent.
Old Sep 30, 2006 | 08:54 PM
All depends if its an interferance motor or not (if the valves take up the same space as the pistons) If its not then you should be ok
Old Sep 30, 2006 | 10:36 PM
but the only thing that i am worried about is that he bent a good amount of pistons b/c isnt the pt motor a detuned srt4 motor? i dont really know but thats what ive heard. if you didnt bend any then all youll need is retime the motor and replace the belt and adjust it. one thing you can do is do a compression check and see if they have compression.
Old Oct 1, 2006 | 09:42 AM
Well if it is that motor... then you will need to replace a few valves... and if you are REALLY unlucky then you will need a whole new engine because the valves would have taken chunks out of hte pistons.
Old Oct 1, 2006 | 02:51 PM
well the motor still is an interference motor no matter how you look at it most likely you bent some valves if it broke while you were driving. If it didnt then you are very lucky. But my guess is you did.
