Tranny Problems?
Old Mar 15, 2007 | 09:16 PM
96eclipsedohc's Avatar
Default Tranny Problems?
ok well i was pulling out and i went about 4 grand in rpm and shifted into second and it was like it went back father than it was susposed to.. And same with all the other gears..Could it be the shifter
Old Mar 15, 2007 | 09:40 PM
Default RE: Tranny Problems?
im not sure what your saying. That it feels like the shifter is moving farther than it should? Are you able to shift into the gears fine
Old Mar 16, 2007 | 07:48 AM
ComposeEvo's Avatar
i'm really trying to help you out here bud, but i just cant make out what your saying? please rewrite in detail what is happening?
Old Mar 16, 2007 | 10:27 AM
RCJr9186's Avatar
do you have a short shifter??? i had this exact same problem with mine. it feels like an e x t r e m e l y long shift and sometimes hard to even find the gear? yea, if you have a short shifter or any kind of aftermarket shifter take your center consol off and just tighten everythng down really good, i used some loc-tite when i did it the second time and never had a prob since.
Old Mar 16, 2007 | 01:10 PM
ok well first of all thanks to all you guys trien to help me and ok here is the problem, its not a aftermarket shifter (stock), ok well yesterday i was pulling out and i went into second kinda hard and then from then on its like the 2nd, 4th, and reverse are really long gears.. maybe something come loose, and like if i'm in 5th and goin to gear down i have to push it to the right until its in the middle and then gear down
Old Mar 16, 2007 | 04:26 PM
RCJr9186's Avatar
i'd pull the center consol off (2 screws on both sides near the back seat, 2 screws under the cup and change holder, and you have to take the radio/ac control trim off and it comes right up) you'll have to remove the shift **** and after tha the entire unit lifts right up. once you do that just shift like you normally do and see if you can see anything wrong with it.
Old Mar 16, 2007 | 04:40 PM
2nd g eclipse gst's Avatar
im gonna have to go with ur shifter cables thats what happend to me right before it snapped...
jp2000
Jan 1, 2012 05:21 PM
TransAmist
Mar 15, 2006 06:47 PM
1997gsteclipse
Nov 28, 2005 07:39 PM
venom3230
Jan 12, 2004 08:32 PM
ikon_01
Sep 8, 2003 01:03 AM
