Transmission
Old Feb 15, 2008 | 07:30 PM
bagaak's Avatar
Default Transmission
hey guys post 3 for today ^^ ok heres the thing, i have a 99 rs manual and AFTER the car has warmed up properly, shifting is as usual, not as smooth as i like. it feels like theres someting holding it back and not wanting to shift.. no grinding or anything like that. if i dont let it warm up, its almost impossible to shift to first and second. what do you guys think it could be? i rescently had my 3rd and 4th synchro's fixed and my clutch changed by a mech. thanks
Old Feb 15, 2008 | 07:33 PM
Rob's Avatar
Rob
Default RE: Transmission
Does it feel like the restriction could be in the linkage? Or like you need to flush the tranny and put some fresh fluid in?
Old Feb 15, 2008 | 07:58 PM
dsm1990gsx's Avatar
Try using bg syncro shift.
Old Feb 15, 2008 | 11:54 PM
estraw's Avatar
bleed the fluid in your master/slave cylinders for you clutch
Old Feb 16, 2008 | 06:37 AM
i think you need to replace the fluid. And like dsm said, BG syncroshift oil is the way to go
Old Feb 16, 2008 | 09:34 AM
TheAdvocate's Avatar
My work talon does the same thing.. Only when it is really freakin cold though..
Old Feb 16, 2008 | 01:18 PM
bagaak's Avatar
alright ill try that, after my next paycheck tho, i was thinking royal purple, anyone use that? i use it in my oil, y not there?
Old Feb 16, 2008 | 03:48 PM
Rob's Avatar
Rob
I use BGII in my evo. It's synthetic tranny fluid and you can find it cheapest at bushurracing.com
Old Feb 16, 2008 | 06:11 PM
98gstspy's Avatar
i have that same problem in my jeep. its all a fluid thing
glennsafrit
Oct 25, 2004 12:29 PM
khscott
Aug 15, 2004 02:38 AM
LESLEY
Jul 19, 2004 08:35 PM
stbmotors
Jul 10, 2004 05:29 AM
