Transmissiong Ticking.
Old May 29, 2006 | 08:55 PM
TX97GST's Avatar
Default Transmissiong Ticking.
I was having some trouble with my tranny ticking the second I touched the clutch pedal. Since I have a 97 GST I get all nervous and think the worst CW. I took it to the Gillman Mitsu. and he assured me it was the Main clutch bering. Not wanting to pay 740 to have it repaird I called around. and a reputable tranny shop said from my description and what I told him the dealer said, that it was not the main clutch bering, but the release bering. A couple of questions I am throwing out here is
1. Is the Main Clutch bering and the Releast Bering the same thing?
2. If I bought a ACT 2600 w/streetdisk and installed would this not correct the problem? or is the bering not accessable but with cracking the tranny open?
3. Will one of these cause me to loose clutch pressure if I don't use the clutch for a while (like on a freeway)?
Thanks
Old May 29, 2006 | 09:00 PM
Default RE: Transmissiong Ticking.
thats a symptom of CW...
Old May 29, 2006 | 09:08 PM
TX97GST's Avatar
I thought the loss of clutch pedal was when you made left turns? I gave the articles about CW to the dealer and he said the ticking was coming from the tranny not the timing side. Even after all that the dealer still says definatly not to CW.
Old May 29, 2006 | 09:20 PM
Ok good. Well i dont really know. It could be a bearing. Yet it could be many many things. I wouldnt know were to start.
Old May 29, 2006 | 10:32 PM
TX97GST's Avatar
If it is the bering, if I had a new clutch, and the bering replace shouldn't that fix it, without costing almost 800 bucks.
Old May 30, 2006 | 10:45 PM
TX97GST's Avatar
How hard is it to change a clutch and release bering on a 2g turbo? I have the Haynes book and it does not look that difficult. The most I have done to a car is change the brakes, sparkplugs on a 3000gt, install HID's, just minor stuff like that. Thoughts?
Old May 30, 2006 | 11:10 PM
5Tizzle's Avatar
my car is outta comission right now too for probably the same reason. If that IS it, the tranny shop nearby said they would charge me 570 to change it out, but they usually charge 650-700
BrunoBoy650
1st Generation
25
Mar 6, 2006 02:08 AM
93eclipsegsx
1st Generation
Jan 29, 2006 02:10 AM
kent man
Jan 2, 2006 04:30 PM
Skoze
Nov 23, 2005 07:48 PM
Daithi
May 29, 2005 06:09 PM
