TROUBLE
Old Dec 21, 2006 | 01:47 AM
5Tizzle's Avatar
Default TROUBLE
Okay. so i was a little low on oil last night so i just went to sleep instead of going out, and this morning i went to get oil in my dads truck, came back, unlocked the car, opened the hood, locked the door(for some reason), checked if i had the key in my hand(i did), walked to the hood, put in some oil, closed the hood, and realized i was missing something....
My question is...How do i break into my car without breaking anything?
Old Dec 21, 2006 | 03:12 AM
racerx55's Avatar
Default RE: TROUBLE
hmm so your key is under the hood, ooops.
if you have power locks shove a hanger down in the window or between the door and seal and see if you can hit the button, if not i dunno
Old Dec 21, 2006 | 03:30 AM
5Tizzle's Avatar
Default RE: TROUBLE
the window is all the way up...
Old Dec 21, 2006 | 08:26 AM
paintballproam's Avatar
Default RE: TROUBLE
you can still do it, that gasket that the window rests against, is so pliable, you could shove a hanger through there and unlock it like nothing,
Old Dec 21, 2006 | 09:10 AM
Default RE: TROUBLE
there is a gap even when the window is all the way up. that is how towing truck guys do it. In my old work van i locked the keys inside and I took the back door apart where the door handle was and picked the lock with a flat head. Dont thing you can do that with a car or truck though cause the rear doors have a plastic panel over the handle and key hole and I took that apart
Old Dec 21, 2006 | 06:19 PM
5Tizzle's Avatar
Default RE: TROUBLE
for future reference to anyone else stupid enough to not get a copy of your car key....
use a hanger and come through the rear part of the window, and it is a lot easier to pull on the door handle than trying to pull on the lock, or press the button.
beetlenut
Jan 22, 2017 06:11 AM
Audioquest
Aug 16, 2004 06:32 PM
SiriusGrrl
Feb 25, 2004 11:31 AM
eclipsegsx95
Feb 19, 2004 05:04 PM
theguy387
Feb 10, 2004 03:45 AM
