Turbo 1997 Mitsubishi Eclipse GS
#31
4 speed overdrive ELC Auto Trans.
I think the previous owner had some problems and ran the car too hard, knew it was about to take a crap, so he sold it to someone he thought would be an unsuspecting idiot.
You're looking at some serious money to fix the car.
I woul personally just put a new long block in it and find out exactly what wrong with the turbo.
It may be nothing at all, or maybe its had an internal failure.
Nothing uncommon.
#32
now now Joshewuhh, no need for the name calling, he didn't know any better. No way to talk to a new person.
now, if we are correct and you have a crankwalked motor, you will need to either buy a new block or rebuild the block:
crank
pistons
rings
rods
main bearings
rod bearings
this will run you apx 700-800 for stock parts. you can sometimes find used blocks on ebay for cheaper than that but it's a timing thing. then you will need to find a new turbo. you can buy used stock turbo's (called a t25) for 100 bucks or less but you risk having the same problem within 10-30k miles... so buying a new one may ensure it to run a longer life.
crank
pistons
rings
rods
main bearings
rod bearings
cjernigan
04-24-2010 09:22 AM
raw
05-06-2008 04:02 PM
butch
04-28-2006 11:34 AM
