turbo
Old Feb 19, 2006 | 11:19 PM
willyd465's Avatar
Default turbo
aight im new to the dsm world and turbos, but i test drove a gsx today and when the car started there was a tick but after idling for about 5 minutes it abruptly stopped. another thing is when accelerating hard and makin boost it stuttered really bad like the ignition was cuttin out. is this normal? it has the stock turbo, as for mods it has light weight flywheel, new clutch, catback exhaust, downpipe, rebuilt trans. thanks
Old Feb 19, 2006 | 11:23 PM
Default RE: turbo
they tick a little when it needs an oil change or tick when crankwalk is coming. (but crankwaly is if you have the clutch pressed down and you hear the tick) a trow out bearing will tick lightly when you let of the clutch as well.
the turbo should make any studdering sound nor should the car feel that way, sounds like spark plugs are bad same thing happend to my buddies AWD TSi and when the pluggs and wires were change it drove great. (his only studdered if the car was floored completely) Id start with a good tune up for that thing and go from there
Old Feb 19, 2006 | 11:25 PM
Default RE: turbo
I have also hear of cases where the throw out bearing is bad sounding when you have a lightend flywheel, it has been described as a marble rolling around in the tranny type of a sound , but im not sure if eclipes do that one I know it happens to MKIV supras
Old Feb 20, 2006 | 12:02 AM
NESpeed's Avatar
Default RE: turbo
ORIGINAL: willyd465
It sounds like the ticking you are describing is lifter tick, usually from low oil pressure, cold weather, or worn lash adjusters(they leak and need to fill back up, so it causes lifter tick)
How bad does it stutter? Like your hitting a wall or just a hesitation?
Old Feb 20, 2006 | 12:42 AM
DSMTalonAWD51's Avatar
Default RE: turbo
all dsms like to make lifter tick noises when they get older, in most cases it is not bad. some people like to upgrade to 3g lifters just to get rid of the sound, but if it gets quieter after it warms up i wouldnt be concerned. cw tick is only going to be heard when the clutch is depressed
Old Feb 20, 2006 | 12:43 AM
BrunoBoy650's Avatar
Default RE: turbo
this is just like my post. "stuttering" my gsx, goes to 4k and hesitates and wont go farther ONLY if i mash it. but if i ease into it, im ok, i DO have the leak in the Oil Filter and Oil Filter Adapter. next, it happens right as boost starts.
Old Feb 20, 2006 | 01:07 AM
willyd465's Avatar
Default RE: turbo
thanks for the help, im not going to get this one the body was pretty bad. is this somethin i should keep an eye out for as i "continue the search"
Old Feb 20, 2006 | 01:44 AM
slow420a's Avatar
Default RE: turbo
ORIGINAL: EMonz57
It sounds like a marbal in a soda can shaking around, whe you depress the clutch and the sound stops... its a throw out bearing.
Old Feb 20, 2006 | 10:02 AM
Default RE: turbo
ORIGINAL: slow420a
ORIGINAL: EMonz57
I know that is what I said in my entire post
Bruno change your spark plugs and wires and you will be all set im guessing
Old Feb 20, 2006 | 01:30 PM
Default RE: turbo
ORIGINAL: EMonz57
ORIGINAL: slow420a
ORIGINAL: EMonz57
thanks
aznspyder
25
Nov 28, 2007 04:57 PM
turbotalon95
Jun 29, 2004 02:38 PM
scrappy24
Apr 7, 2004 11:04 PM
GSkiDD
Jan 29, 2004 08:04 AM
Eclipse_GSX
Jul 10, 2003 02:34 PM
