Turbo and Fmic?
Old Feb 9, 2008 | 03:00 PM
Default RE: Turbo and Fmic?
No its not. I ran a 255lph without a tune.
What do you think a fuel pressure regulator is for?
Old Feb 9, 2008 | 03:02 PM
Rob's Avatar
Rob
So you adjusted your stock fpr to handle a 255lph fuel pump?
Old Feb 9, 2008 | 03:03 PM
Well... my fuel pressures at idle was all over the place... but the car handled it fine.
A 190lph fuel pump doesnt require an aftermarket FPR, the stock one can handle it just fine.
Old Feb 9, 2008 | 03:15 PM
Rob's Avatar
Rob
Yes, but you still need to "trick" those injectors unless fuel cut is your best friend. I'll always say if you drive around with a half *** fuel set-up you're looking for trouble.
Old Feb 9, 2008 | 03:16 PM
No you dont...
and it holds off fuel cut for another few psi.
Old Feb 9, 2008 | 03:20 PM
Rob's Avatar
Rob
Okay, i'll just put it this way then. If he wants to get anything out of that turbo, he'll want full fuel mods, and a good tune. Otherwise, he can enjoy his starving 16g.
Old Feb 9, 2008 | 03:29 PM
Dude at like 15psi the 16g will be fine. With a 190lph fuel pump you can run about 17 maybe...
Then when you have the cash, you get the SAFC and injectors...
BrunoBoy650
Apr 10, 2007 03:27 PM
ziggy88
Mar 17, 2006 01:00 AM
get435
Dec 18, 2005 09:55 AM
DSMDUDE
Mar 30, 2005 09:59 PM
t3t4turbo
Feb 20, 2005 03:25 AM
