turbo timer and boost controller
i've been looking at the prices and everything for manual vs. electronic. the best manual boost controller i've found is the Greddy TVVC which is 189. however the Greddy Profec Type-S i've found for 150 and is just as easy to use as a manual however it has the accuracy and speed of electonic. Also you can get an optional switch to go on your steering wheel or anywhere for that matter that will turn your boost from you Lo setting straight to your High setting... sounds like a good deal to me
ORIGINAL: RCJr9186
DONT waiste your money on a electric unless it is cheap used and you know how to use it.
and Talon4show they have Boost, Gain, and I know the AVCr does Duty cycle as well
ORIGINAL: talon4show
Jeff is right...you do not need a turbo timer on the stock turbo. The T-25 is water cooled and no oil cooled so it is fine. HOWEVER, letting your car idle for a few seconds (usually between 15-30) is a good idea.
ORIGINAL: RCJr9186
joepmbc.com......he makes a NICE manual boost controller for 45$!!!!! I have it on my 97 GST spyder and it hardly ever spikes. He has two versions one is for sensitive use (stock turbo) and a normal one (for users pushing 7psi over stock).
spyder4g63t
06-26-2007 04:16 PM
importorigins
07-11-2006 02:18 AM
