Turbo Upgrade Options
Old Aug 15, 2008 | 08:31 PM
victim619's Avatar
Default Turbo Upgrade Options
As some may know I have a 2.4L spyder GS
heres what im about to drop in:
Jdm Evo 3 head (basically whole top end of a evo 3) with 5 angle valve job all internals after market. 450 injectors. coil on plug setup. Stock turbo setup. Gauges all 3 with pod. Greddy Type-S BOV. FMIC. and a stock Downpipe. K&N Intake. MBC. gst ECU.
Im going to run with a stock turbo setup for a month to work the bugs out. But after upgrade time so im saving money but I have to figure out which turbo would be best. I want something that will let me run low boost through the city because its my daily driver (and to save a lilgas haha), but when I turn up the boost I want it to make enough power to play with sti's, mustangs, gst's, rsx-s etc....I was looking into a Evo 3 16g, but I need some advice on what to get, I also notice that some require an install kit, since my car is a 2g but it has a 1st gen top half would I need an install kit for the turbos that require one for the 2g?
Old Aug 16, 2008 | 09:52 AM
Default RE: Turbo Upgrade Options
all you need is a j-pipe for the 16g, yes you need it. and that is the turbo i would go with
Old Aug 16, 2008 | 11:48 AM
victim619's Avatar
i was also lookin into the to4b v-trim its rated up to 600hp and at 10psi with a good tune its at about 300hp but its a bolt on so im not sure if bolt on turbos are that great, but it might mess it up from being a street dd car. this is a newb question but where does the j-pipe connect to? because im droppin a 14b in for now to break in my new setup
Old Aug 16, 2008 | 12:11 PM
dsm1990gsx's Avatar
I would also say go w/ an evo316g since its gonna be a dd, the j pipe is what your gonna need to run the fmic piping. It come off the compressor housing and pretty much faces down. Do a search you find it.
Old Aug 16, 2008 | 12:21 PM
victim619's Avatar
im getting custom fmic piping cant i just run it without a j pipe SINCE my piping will be custom or will that just be easier to run it with a j pipe. i know TE assured i would need it but like i said im getting custom piping anyway.
Old Aug 16, 2008 | 12:23 PM
dsm1990gsx's Avatar
ORIGINAL: victim619
If your running a 14b/16g you will need one.
Old Aug 16, 2008 | 12:40 PM
victim619's Avatar
I did a google search on the J pipe and it looks like I have one. Is that it?
Old Aug 16, 2008 | 12:45 PM
dsm1990gsx's Avatar
Yeah thats the stock one and its set up for the stock smic, you'll need one that faces down to run the piping for a fmic.
here is a link http://cgi.ebay.com/ebaymotors/95-99...spagenameZWDVW
just to give u an idea.
Old Aug 16, 2008 | 12:58 PM
victim619's Avatar
Wheres a good place to get one? I'm looking for a used one but not sure if I could find one in time.
Old Aug 16, 2008 | 01:32 PM
dsm1990gsx's Avatar
Check dsmtrader.com or dsmtalk.com for a used one. You can get one really anywhere they are all pretty much the same thing.
