Turbocharging
Old Apr 20, 2005 | 02:12 AM
KillerEclipse's Avatar
Default Turbocharging
I was wondering if anyone knew where I could a turbo kit for a 3rd generation eclipse. The V6 model. And also one of my friends told me that it would be a good idea to get titanium forged pistons and forged rods if i was going to turbocharge my engine. How much of a difference does changing the pistons make, and is it even nesseccary?
Old Apr 20, 2005 | 05:12 PM
Sanguinius's Avatar
Default RE: Turbocharging
There are various places to look but know whether or not your engine can handle the turbo before buying it. You can try searching e bay or yahoo auctions. Or look into local pro shops. as for the pistons it should be fine with lower pressure levels but when you go to the higher boost levels then you might need to consider getting stronger pistons but I doubt it. The forged pistons and rods may be lighter and rods will be necessary to get when you get to higher pressure levels as well (I'm not sure of exact numbers I'd guess over 18-20# of boost you may want to consider getting the new pistons and rods). But if they ARE lighter then you should get a small increase in the power output as well.
Old Apr 28, 2005 | 11:21 AM
patsevo8's Avatar
Dougs dyno power in Las Vegas. He is a total DSM freak and makes killer turbos.
Old Apr 28, 2005 | 04:12 PM
DSMTalonAWD51's Avatar
3rdgen eclipse is not a DSM. I havnt seen any kits for the 3g eclipses, im sure you could make one custom, but i wouldnt boost over 5-8lbs without lower compression pistons and a built motor for a turbo.
Old Apr 28, 2005 | 06:12 PM
patsevo8's Avatar
I didn't mean it like that. I meant it that he makes kits for the 3g eclipse.
Old Apr 28, 2005 | 11:58 PM
I just went to his website and he does have a kit for a v6 eclipse, he even has pistons, rods, and rings, i think i will go ahead and get my turbo kit from him. Thanks
Old Apr 29, 2005 | 10:37 AM
newEclipse's Avatar
about how much does that cost for that car. I have the same one and was looking to get a turbo myself
Old Apr 29, 2005 | 11:17 PM
the turbo kit itself is priced at $3,000. but all of the engine mods cost seperate.
pbbg
Sep 23, 2021 05:19 PM
avriethoff
1st Generation
Dec 12, 2007 11:20 AM
Memphetic
Apr 19, 2005 11:39 PM
