Type S BOV
Old Dec 27, 2004 | 09:59 PM
Xit40's Avatar
Default Type S BOV
Ok quick question I have a Greddy Type S BOV that I just installed on my Eclipse GSX and I was wondering what the nipple on the back of the valve is for. I have the boost reference line hooked up so does that on just get clamped off or what?
Old Dec 28, 2004 | 01:28 AM
midnght's Avatar
Default RE: Type S BOV
You use the top one and leave the lower one alone.
Old Dec 28, 2004 | 02:44 AM
Xit40's Avatar
ok well that's all well and good but what is it for? I searched around on the net and found something that said you could hook it up to the turbo outlet pipe so it would get pressure even when the manifold is pulling vacuum, which would make the BOV slightly quicker and more effective. Is this true?
Old Dec 28, 2004 | 04:37 PM
midnght's Avatar
Yes, but sometimes (if you are boosting more than 20psi) it will cause a premature release. Nothing sexual about a nice bog in the middle of a good pull down the strip/street.
If you hook it up to a boost source BEFORE the Bypass valve itself (I.E. Turbo Comp Cover, Outlet pipe, IC piping elbow under fuse panel) you will get the same reward.
*I have been running it without a line since I was boosting 19psi. I have NO problems with needing a CRISP release. Pressure is pressure and it will leave*
Old Dec 30, 2004 | 04:20 PM
Xit40's Avatar
Aight thanx for the info
Old Jan 2, 2005 | 11:05 PM
vertstanggt's Avatar
How do you like your bov? I will probably be getting one sometime soon.
Old Jan 3, 2005 | 01:29 AM
midnght's Avatar
I have boosted up to 30psi with it and NO problem. It was a freak thing after I put my setup in and was promptly adjusted, but it did hold and felt AWESOME>
Old Jan 3, 2005 | 02:55 PM
LOL, I bet it did.
burnmyeyes
Jan 2, 2008 09:04 PM
agallardo
Feb 5, 2007 03:48 PM
Gstfat
13
Nov 7, 2006 08:26 PM
mattsride
Mar 3, 2006 09:29 AM
GReddyGST
Aug 1, 2005 04:09 PM
