UDP Install Write Up?
Old Aug 22, 2007 | 02:36 PM
willdue's Avatar
Default UDP Install Write Up?
420a, anyone have a write up for install? And what size belt?
Old Aug 22, 2007 | 03:46 PM
silvercoupe97's Avatar
Default RE: UDP Install Write Up?
I can look for one for you.
Old Aug 22, 2007 | 08:51 PM
willdue's Avatar
thanks, i couldt find any actual write ups
Old Aug 23, 2007 | 02:16 AM
Remember, the 420a also came in the Avenger/Sebrings in the same configuration
Old Aug 23, 2007 | 02:35 AM
Original poster Mopar McNeer
I just got mine in the mail today. I'll be installing it this week/weekend. It appears to be very nicely constructed and should work great...
The belts you need (according to the instructions)
Gates brand : Alt: K040320 (32.75 inches or 830 mm)
P/S-A/C K050490 (49.5 inches or 1255 mm)
But I should also note--that when my car is at idle (or idling at a stop with my foot on the brake), the stereo (amp and subs) draws enough to dim my lights (drops down to 12v)--where it did not before. Obviously the alt is underdriven (most noticable at idle), So I gave up some idle power, but once I get rolling--I have no problems and the volts stay at about 14v and no dimming. I just turn my tunes down to keep from looking like that dumb *** whose lights dim (greatly) with each hit of bass....
****And as I posted in a post above--it will require new alt belts and new A/C-P/S belts. Below is a pic for comparison between the UDP and the factory one....the difference is easy to notice.
If you get these from CustomGrills.com
Made from 6061-T6 aluminum and anodized.
Underdrives the crank 20%.
Underdrive crank weighs 1lb 3.4 oz
Calculations show 8-9hp gain to the crank
Will need to get belts (not included):
Belt part numbers for accessories
#4050490 and #4040320
These are Goodyear
The install isn't very difficult. It is semi-difficult to get to though. Remember, it's located on the crank and it also replaces the harmonic balancer.
Look here for referrence
http://www.customcargrills.com/products.asp?id=34
Old Aug 23, 2007 | 11:26 AM
willdue's Avatar
Still no write up? lol. Man i searched for hours and found nothing. Its the one on top in the front i thought? Or the one in the back?
Old Aug 23, 2007 | 04:02 PM
Bro, it's on the crank. The write up is in a Haynes/Chiltons manual on removing the Harmonic balancer/crank pulley. The UDP is the only pulley with two accessory belts on it, just like in the pic.... It's not hard and there's no shortcuts. Look at your pulley, plan your attack and go for it. If you're that worried about it, take it to a shop and let them do it. Chances are, they can get the belt replacements for you too.
Old Aug 25, 2007 | 12:56 AM
chopper1's Avatar
I have one on mine and the P/S and A/C belt is as mentioned in the above post, a -----490.
One size smaller than the stock belt which was a ----510.
Jazar
Feb 2, 2008 06:18 PM
willdue
Aug 6, 2007 08:14 AM
GRIDLOCK
Feb 28, 2004 03:57 PM
