write up on changing thermostat?
Old Aug 3, 2007 | 05:11 PM
willdue's Avatar
Default write up on changing thermostat?
Anyone have one for a 420a?
Old Aug 3, 2007 | 05:38 PM
silvercoupe97's Avatar
Default RE: write up on changing thermostat?
It's easy. Get the manual for your car, clear out the coolant, flush it out with a hose, remove the old thermostat, install the new one, fill it up with the 50/50 mix, run the motor to purge the bubbles by leaving the cap off and fill as necessary, fill your resevoir all the way up, drive your car around a bit, done. You'll notice that your resevoir bottle is at the "full" line and the excess has evacuated the bottle.
See, easy
Old Aug 3, 2007 | 05:55 PM
willdue's Avatar
how do I flush it?
Old Aug 3, 2007 | 06:10 PM
Stick a hose in one of the openings and the water will flow freely since the thermostat is what keeps it from flowing. The water pump's impeller won't hinder flow much.
Old Aug 6, 2007 | 08:14 AM
i never flu****, i usually just drain it with the plug at the bottom of the radiator. But he is right, just unplug the termostat and plug the new one in. Pretty simple
edster1
Oct 15, 2010 01:31 PM
willdue
Aug 25, 2007 12:56 AM
GRIDLOCK
Feb 28, 2004 03:57 PM
