underdrive pulley
Old Feb 28, 2006 | 04:51 AM
GST's Avatar
GST
Default underdrive pulley
does tis help increase hp and faster from a line? before 3000rpm? O_o
Old Feb 28, 2006 | 10:35 AM
eclipsed4u's Avatar
Default RE: underdrive pulley
ORIGINAL: GST
it won't do alot for an almost stock car. it may add up to about 5HP.
Old Feb 28, 2006 | 11:03 AM
93eclipsegsx's Avatar
i dont know if this will help, but there was a topic on pulleys
https://mitsubishiforum.com/m_49390/tm.htm
Old Feb 28, 2006 | 05:32 PM
GST's Avatar
GST
ohh. thanks! i have a theory.. hmm.. if you use cheap pulley.. if it creaks and break.. would the timing belt will be screwed up.. and you engine will go.. no no ?!?!? hmm... too much risk.. haha
Old Feb 28, 2006 | 05:38 PM
get435's Avatar
If the crank pulley is to bust or get thrown the timing belt stops moving but teh crank dose not so bye bye head all the valves get a new bend in life oh and the car will not work and you may junk a piston or two if the pulley is to break.
Old Feb 28, 2006 | 06:31 PM
slow420a's Avatar
The timming belt does not ride on the udp, it rides on a crank sprocket, if you break a udp(which is nearly impossible) you altinator, powerstearing, and ac wont work. By buying a cheap pully you run the risk of getting one thats not balanced correctly which will give you some nasty vibration.
timming belt circut, note that the udp isant installed yet.
Old Feb 28, 2006 | 07:14 PM
GST's Avatar
GST
wow!!! it's huge!!!!!!! thanks!!
outrum
May 19, 2007 12:53 AM
1.8Underdog
1st Generation
Jul 19, 2006 09:28 AM
dirtwagon
Jun 25, 2006 02:51 PM
whitestallion10
Jan 6, 2005 01:20 AM
FatalJRA
Sep 22, 2004 11:34 AM
