Upper/Lower Radiator Hose Temperature
Old Jan 17, 2007 | 11:49 AM
Joel_CA's Avatar
Default RE: Upper/Lower Radiator Hose Temperature
It would be best if you were more specific with the yearof your model. I have seen several Gen III modelsfail due to thea bent blend door cable. To check, have someone operate the temperature **** while you inspect the valve at the heater core. More than likely , the cable that actuates the valve is bending rather than switching fromcold to hot position or from hot to cold. If the cable IS bending, you can try disconnecting it and straightening it - but likely it will just happen again leaving the only remedy as replacement. If it's not bending, see if there is any indications that it has bent or is intermittently bending.
J
J
Alex Hernandez
Nov 4, 2013 08:13 PM
Evo2nv
Nov 19, 2007 09:32 PM
micahman
Mar 3, 2006 10:52 PM
DixonsGst
Oct 21, 2005 04:52 PM
Bearwater
Aug 22, 2005 12:22 AM
