Venom Fuel Injectors, Venom Control Module
Old Apr 21, 2005 | 02:16 PM
Laxstar785's Avatar
Default Venom Fuel Injectors, Venom Control Module
i was just wondering if these two things could just be put into a stock 99 eclipse spyder, im just looking for some small power gains nothing really that big. I cant really find many things, i saw these though just wondering what anyone thinks about this?? And is it worth putting a set of pulleys in the car? i have seen unorthodox pulley sets around?
http://www.sportcompactonly.com/prod...tm_medium=shop
Old Apr 21, 2005 | 03:43 PM
DSMTalonAWD51's Avatar
Default RE: Venom Fuel Injectors, Venom Control Module
those will do nothing for a stock eclipse. are you turbo or non turbo? if you are turbo there are a few 'free mods' you can do to gain power and just get an intake filter and a boost controoler. dont waste money on pullies unless you are non turbo, they do almost nothing except make your air conditioner warmer
Old Apr 21, 2005 | 03:48 PM
Sanguinius's Avatar
What exactly do the puleys do for a nonturbo then? And should I get a turbo or turbo the non then should I ditch the pulleys if I have them?
Old Apr 21, 2005 | 04:05 PM
pulleys do the same thing for all cars, they extract a couple extra hp out the motor by making all your belts run slower (ac, steering etc) but the fact that they only give you a few hp make them not really worth it for a turbo car, and you ahve to live with the inconvienence of a crappy ac etc. You could spend that kind of money on something much more worthwhile. for non-turbo cars it may be worth it though because theres only so much you can do to a non turbo engine to make more power
Old Apr 21, 2005 | 07:03 PM
Sanguinius's Avatar
But by making the belts run slower won't that also affect the output power of the alternator? I plan on running a decent system in there so pulleys will probably be detrimental right?
Old Apr 22, 2005 | 06:07 PM
wicked_outlander's Avatar
does anyone out there had their control module installed?? keep hearin lot of stuff about this control module...some says, wont fit right for the eclips's.
Old Apr 22, 2005 | 06:09 PM
ORIGINAL: Sanguinius
i'll, buy a hyper voltage system instead.
Old Apr 28, 2005 | 11:03 AM
patsevo8's Avatar
You're going to waste your money on a set of pulleys, especially unorthodox. They are cheap!
You're, unfortunately not going to get any hp gain from the control mod or injectors. Those accessories don't give hp.
RejectJC
Jul 24, 2007 11:25 AM
agallardo
Feb 22, 2007 03:46 AM
sketterman05
Mar 13, 2006 07:34 PM
vpellizzi
Aug 4, 2005 09:17 AM
rnpoo7
Jan 31, 2005 02:43 AM
