very strange idle issue
Old May 28, 2007 | 02:59 PM
Ziggy's Avatar
Default very strange idle issue
hey i wonder if any of u guys can help me. I idle a little higher than i would like. when i start the car it races up to sometimes 2500 rpms before very slowly coming down to a 1000rpm idle. if i pull off right away the rpms shoot up every time i use the clutch to switch gears. I have to let it sit for like 15 minutes and then this problem is lessened. but if i turn it off and turn it right back on again i would have to wait another15 minutes. has anyone every heard of that?
Old May 29, 2007 | 12:45 AM
Simss's Avatar
Default RE: very strange idle issue
well first off, what kind of car is it?
you may want to check and see if your MAS is plugged in correctly
what it sounds like to me is a vacuum problem so you may want to open your hood while the car is started and listen for a hiss or look for a unhooked hose
Old May 29, 2007 | 10:28 AM
Ziggy's Avatar
sorry bout that, its a 95 eclipse non- turbo
Old May 29, 2007 | 01:14 PM
Hey, do you have any exact compression numbers from the break in a while back?
Old May 29, 2007 | 01:24 PM
Ziggy's Avatar
i dont have an exact compression #. the guy said it was bumped up a whole number but i can't really trust that guy and i havent had an opportunity to get it tested yet
justin210485
Mar 6, 2015 10:11 AM
armymen
Apr 20, 2012 11:39 AM
servizluxor
Jan 25, 2012 02:53 PM
Rye
Jan 29, 2011 06:44 PM
chasha82
May 25, 2006 02:00 PM
