wastegate
Old May 22, 2008 | 08:36 AM
dsmclay's Avatar
Default wastegate
When I connect the wastegate to the 14b turbo what do I use to hold the wastegate from sliding off that little flapper.
Old May 22, 2008 | 09:42 AM
jerusry's Avatar
Default RE: wastegate
you either use a c-clip or a cotter pin. is they a hole or a little indent cutout all the way around the thing the rod slide over? you r talking about connectin the acutor to the flapper outside the turbo right? or you talking about connecting the flapper to the swivel thing inside the turbo?
Old May 22, 2008 | 03:49 PM
dsm1990gsx's Avatar
Cotter pin
Old May 24, 2008 | 02:03 PM
and just so you know. Your not connecting the wastegate to the turbo. The wastegate is inside the turbo. What your connecting is called an actuator.
Nubiebubie_GSX
Jun 12, 2006 03:18 AM
96tsi
Apr 11, 2006 12:28 AM
TheAdvocate
Feb 9, 2006 07:33 PM
matt02708
May 14, 2005 01:07 AM
devildicer
Aug 13, 2004 02:39 AM
