whadyathink?
Old Feb 19, 2008 | 09:49 AM
tuckGST's Avatar
Default whadyathink?
I've been looking for my project engine and came across this...
http://atlanta.craigslist.org/pts/565417261.html
Is it worth rebuilding? what else would I need?
Old Feb 19, 2008 | 10:06 AM
dorian7's Avatar
Default RE: whadyathink?
I wouldn't get a 7 bolt do the 6 bolt swap so that you NEVER have to worry about crankwalk again.
Old Feb 19, 2008 | 10:08 AM
wow even if that was a shell, thats not bad
Old Feb 19, 2008 | 10:13 AM
tuckGST's Avatar
I'm gonna put in about a year's worth of time into it. Is there anyway to build a 7bolt to prevent CW? can a 6bolt crank fit in a 7bolt block?
If not, then I need to be looking for a 6blot.
I want the engine to put down HP in the upper 400 range, so the block will be built up.
Old Feb 19, 2008 | 10:34 AM
Just build up a 7 bolt. There is nothing wrong with that. If your starting from sctratch you wont really have to worry about it. There are plenty of successful high hp 7 bolts
Old Feb 19, 2008 | 02:42 PM
dorian7's Avatar
http://www.magnusmotorsports.com/tech/crankwalk.htm
That has a bunch of great info in it, you should take the time to read the whole thing.
