What psi is safe on 97 Gst?
Old Oct 20, 2008 | 12:27 AM
Russianfart's Avatar
Default What psi is safe on 97 Gst?
hello, i recently got a mbc for my 97 eclipse gst, i believe its a 7-bolt, it has a 1st gen turbo(Tdo5h), custom air filter, cat back exhaust and thats about it. it sits on 8 psi stock right now, so i was wondering what a safe boost would be, i was thinking around 12 but do you guys think thats too much?
Old Oct 20, 2008 | 04:35 AM
silvercoupe97's Avatar
Default RE: What psi is safe on 97 Gst?
Before you raise the boost pressures, get a boost gauge. The stock one isn't accurate enough, so don't settle with what it gives you.
Old Oct 20, 2008 | 06:46 AM
And yes 12psi is fine. You can actually run 15psi safely
Old Oct 20, 2008 | 06:53 PM
DixonsGst's Avatar
You might wannainvest inan aftermarket BOV cause the stock BOV (blow off valve) wont hold any higher than 12psi.
Old Oct 20, 2008 | 07:30 PM
@silvercoupe yea i have an aftermarketboost gauge as well.
Old Oct 20, 2008 | 07:33 PM
dsm1990gsx's Avatar
If your gonna run 15 psi I would highly suggest rewiring the fuel pump.
Old Oct 20, 2008 | 10:06 PM
needsagst98's Avatar
just get a walbro 190lph and u can go higher like 20psi, if you would like. im just giving you an idea here. just make sure u have the other supporting mods like aftermarker bov and stuff. if u want i can sell u a uicp from rre for 55 bucks flanged for greddy bov. if u dont have one
Old Oct 21, 2008 | 08:19 AM
I would NEVER run 20psi on a stock T25...needsagst....what are you thinking? haha. You really shouldnt be running any more than 17psi on that stock turbo because its useless.
But to really just givea staight answer to the OP as far as what to run right now...i say 15psi. I ran that every day onmy stock talon (all i had was a BOV)
Old Oct 21, 2008 | 10:34 AM
te read what he said. he has a 1st GEN turbo 14b. u cant run a t25 that high you would blow it to pieces and it would screw everything up. i have a t25 and i run 15psi. he doesnt have a t25 by what he said
Old Oct 21, 2008 | 10:42 AM
dsm1990gsx's Avatar
The stock 14b can handle 18psi all day w/o any problems, you can run more but its not really doing much. But on a stock fuel system 14-15psi is fine like what TE said.
