what to use for transmission oil
Old Oct 26, 2006 | 03:43 PM
5Tizzle's Avatar
Default what to use for transmission oil
what weight do you use?
Old Oct 26, 2006 | 04:05 PM
5Tizzle's Avatar
Default RE: what to use for transmission oil
Nevermind...found in in the chiltons, but just for search purposes the oil to use is
"Hypoid gear oil SAE 75W-85W or 75W-90W when conforming to API specifications GL-4 or higher"
Old Oct 29, 2006 | 02:36 PM
2insane's Avatar
For AT tranny's plymouthlaser.com suggests: As for Tranny fluid, I used Mitsubishi Diamond ATF up until the shift kit. The OEM fluid is more expensive (surprise surprise) than B&M TrickShift. So, I picked up a bunch from PepBoys and use it only. Its hard to tell which fluid is better due to the fact the shift kit was put in at the same time, which of course makes it feel better.
Old Oct 29, 2006 | 03:41 PM
paintballproam's Avatar
i use royal purple 75w90
Old Oct 29, 2006 | 05:27 PM
2nd g eclipse gst's Avatar
while were on the subject how often should you put transmission fluid in a manual???
way2fast
Dec 22, 2013 08:54 AM
cdvyas20
Feb 19, 2013 06:24 PM
IanHancock907
Jan 6, 2012 11:54 PM
TurboH22
May 11, 2007 11:05 PM
hereclipse
Jan 23, 2005 06:30 AM
