Whats the diffrence???
Old Apr 15, 2006 | 11:38 PM
bagz's Avatar
Default Whats the diffrence???
if you take the valves and everything else out of a head so its just the metal from a 2.0 dohc turbo and to a 2.0 dohc non turbo whats the diffrence?? and the same thing with the block whats the diffrence??
im making a race engine and i have the non turbo but i want turbo. im replacing everything anyway but i dont want to do it to mine if theres a diffrence between the two.
Old Apr 16, 2006 | 01:49 AM
ictponder's Avatar
Default RE: Whats the diffrence???
difference*
Old Apr 16, 2006 | 05:01 AM
5Tizzle's Avatar
There is no difference. If theyre both the 4g63, its just the difference of a turbo being bolted on or not.
Old Apr 16, 2006 | 09:10 AM
ORIGINAL: Jeffisdecentttttt
WRONG THE PISTONS SHOULD BE DIFFERENT. NON TURBO USES HIGHER COMPRESSION PISTONS OTHER THAN THAT THERE MAY BE VERY LITTLE DIFFERENCE. (THATS PROVIDING ITS A 1G NON TURBO 2.0)
Old Apr 16, 2006 | 03:58 PM
bagz's Avatar
yea but i said if you take everything out. im replacing everything anyway so i should just get a non turbo right? because its cheaper
Old Apr 16, 2006 | 04:25 PM
ORIGINAL: bagz
it doesnt much matter I dont thing. if your building it completelty then it make no difference. I dont think the crank is differnte.
And sorry about the CAPS lock on my other post[:@] didnt know that I had the it turned on it was early lol
Old Apr 16, 2006 | 05:33 PM
bagz's Avatar
lol alright i have the 1g non turbo 6 bolt but theres some stripped bolts and stuff like that. should i get a new engine and build off that one or use this one?
Old Apr 16, 2006 | 05:41 PM
5Tizzle's Avatar
ORIGINAL: EMonz57
o woops. i didnt see that he was talking about the block. i only thought he was talking about the head...guess i wasnt paying attention...
Old Apr 16, 2006 | 08:39 PM
slow420a's Avatar
the blocks are different. The n/a block has a different style oil pump routing though it making the oil pressure lower then a non turbo.... which is bad if you want to make high hp# I would recomend getting a turbo block if you going to build it.
Old Apr 16, 2006 | 09:04 PM
ORIGINAL: slow420a
did not know that
