when I push clutch in - it won't turn over
Old Aug 12, 2006 | 04:40 PM
hondo21's Avatar
Default when I push clutch in - it won't turn over
My son has a 95 Eclipse GS 5 spd. 2.oL non-turbo.
It will not even try to turn over when we push the clutch in. All gauges come on, so it seems like the switch that is supposed to work when you push the clutch in is not working or something.
My son can eventually get it to start if he jams the clutch in and out a bunch of times, it will sometimes work. Now I can't get it to work at all. I checked the ignition switch fuse and it's OK.
Is there a "neutral safety switch" or something like that?
Where should I start to look first to diagnose this?
Thanks!
Rob
Old Aug 12, 2006 | 07:21 PM
NESpeed's Avatar
Default RE: when I push clutch in - it won't turn over
ORIGINAL: hondo21
Thanks!
Rob
Find the clutch pedal assembly under the dash, hunt around it till you find a button looking piece the gets pressed when the clutch gets engaged. When you find that unplug it and try to start the car. When you unplug it, it bypasses it and the car should start with out the clutch depressed. Good luck.
Old Aug 12, 2006 | 09:58 PM
hondo21's Avatar
You're a life saver!
This was the problem as the little plug that goes on the end of the clutch arm was broken and laying on the floor This plug hits the button on the switch when the clutch is pushed in. I disconnected the switch and she started right up. This will get us by until we can replace that broken plug..
Thanks a million!
Rob
Old Aug 13, 2006 | 12:43 AM
BrunoBoy650's Avatar
ORIGINAL: hondo21
Thanks a million!
Rob
you dont even need the plug
phatmatt
Jul 16, 2017 12:27 PM
drejal
Jul 7, 2013 11:23 PM
ryanmd82
Feb 8, 2013 07:47 AM
Raquel
Feb 12, 2010 08:24 PM
dornstar
May 22, 2006 04:58 PM
