why do all eclipse gs spyder have amf's
Old Oct 31, 2005 | 08:42 PM
97GSpower's Avatar
Default why do all eclipse gs spyder have amf's
why do all eclipse gs spyder have amf's and the reugular ones dont and where can i get the intake tube afrte the amf i have the part before the amf
Old Oct 31, 2005 | 08:45 PM
Default RE: why do all eclipse gs spyder have amf's
do you mean MAF?? if so they all have it, and it measures the air flow. as far as the lower pipe it depents on what you have already is it a name brand pipe or any certain color? I think injen sells the lower pipe seperate
Old Oct 31, 2005 | 08:53 PM
Joel_CA's Avatar
Airflow Meter's are what Mitsubishi uses to determine the amount of air (as well as it's temperature and barometer readings) the engine is taking in in all of their vehicles. It is this sensor that the PCM uses to caluculate how much fuel to inject to match the incoming air. The "other" engine is a Chrysler engine which uses a MAP sensor to determine the amount of airflow into the engine. The PCM determines how much air is coming in based on a vacuum signal to the MAP sensor and injects the appropriate amount of fuel to match.
Joel, CA
Old Oct 31, 2005 | 09:14 PM
Sanguinius's Avatar
*WARNING Partial threadjack* I know what the MAP and MAF's do just out of curiousity what does MAP stand for (I know what MAF stands for too). *END THREADJACK*
Old Oct 31, 2005 | 09:55 PM
eclipsed4u's Avatar
ORIGINAL: Sanguinius
Manifold Absolute Pressure
Old Oct 31, 2005 | 10:43 PM
slow420a's Avatar
I love my map.
Old Oct 31, 2005 | 11:06 PM
ORIGINAL: slow420a
I love my map.
Mee tooo, I wish the EVO used MAP rather than MAF.
Old Nov 1, 2005 | 02:31 AM
Joel_CA's Avatar
Just as an FYI, Newer Mits engines uses both a MAP and a Mass Airflow Sensor although the map is basically used to verify EGR operation instead of fuel control.
Joel, CA
Old Nov 1, 2005 | 03:28 PM
DSMTalonAWD51's Avatar
ORIGINAL: Joel_CA
Joel, CA
yup.
Old Nov 1, 2005 | 04:17 PM
Sanguinius's Avatar
Really that's a new one I didn't know... Why do they ALWAYS have to change shyt on us???
