Wierd Smoke Problem
Old Nov 15, 2005 | 01:56 AM
  #31
Polonez's Avatar
Default RE: Wierd Smoke Problem
i dont plan to vent the bov. going back to the intake... i dont care about the "cool" sounds haha
Boost creep eh????? hmmmmmm
how baad???? i was gonna ask what it does and how to prvent it but i will just search
Old Nov 15, 2005 | 08:43 AM
  #32
slow420a's Avatar
The only way to compleatly elminate it is to get an externial wastegate. That requires drilling the stock manifold(i dont reccomend) and welding on a flange, then recirculating it. The externial wastegate is a tricky thing. IF you use the stock manifold the exaust is going to favor the turbo, you will get a quick spool but no a solid boost setting, where if you get an aftermarket one(some) favor the WG which is going to give you a positive boost pressure but creat a bit of turbo lag. But from what I understand the evoIII has boost creep, where the s16g dosent. I dont know why.
Old Nov 15, 2005 | 12:40 PM
  #33
Polonez's Avatar
the one im looking at is a ported evo III made by stone racing in Philly...
will the porting help the boost creep
Old Nov 15, 2005 | 08:18 PM
  #34
slow420a's Avatar
not too sure, It may help a bit but because the exaust can leave the turbo quicker and keep it from overboosting but I am not sure it it will totally solve the problem.
Old Nov 16, 2005 | 04:17 AM
  #35
Polonez's Avatar
i talked to a local turbo shop and they told me that getting a bigger flapper will eliminate it also
Old Nov 16, 2005 | 10:54 AM
  #36
slow420a's Avatar
Go fo it then, if it dosent fix the creep... beat them with it.
Old Nov 16, 2005 | 04:17 PM
  #37
Polonez's Avatar
yep just placed the order for this bad boy...... waiting for them to upgrade the flapper and while im at it im gonna port the exhaust manifold, 02 housing and all the goodies
Old Nov 16, 2005 | 08:33 PM
  #38
slow420a's Avatar
awseom its going to sound pertty cool.
Old Nov 21, 2005 | 12:42 AM
  #39
99clipsgst's Avatar
Ok So i'm going to replace my head gasket and piston rings timing belt, water pump and tenioners. What are some good brands to look for. i heard top line isnt to good. I only plan on boosting to 14 or 15lbs. Also while im in there i heard of the balance shaft removal kit. What does it do how much hp will it add and how much work does it take for it to work. Like do I ned t do more then buy the $49 kit. Finally what are some other upgrades that I can do while Im doing the head gasket and stuff?
Old Nov 21, 2005 | 10:10 AM
  #40
get435's Avatar
first off are you going to replace the rings? if so have you ever done it and do u have the proper equipment? inner dimention micromter jsut wondering becuse if u have never replaced rings or do not have the precise tools to do so i would not attempt it.
