Wiring Diagram
Old Jul 20, 2006 | 08:55 AM
djfrog2001's Avatar
Default Wiring Diagram
First of all this what I am trying to do. I just purchased a set of foglights that came with the standard rocker switch to activate them. I would like to set them up so that they turn on and off with the headlights, I don't want to tap directly into the hot wire from the lights (to avoid popping fuses) but I know that it will either have to be that or tap into the headlight relay. The foglights came with a relay so what I would like to do is run the wire currently going to the switch and tap into the headlight relay for the car. If this makes sense to anybody I will be surprised. What I would like to know is if the wiring diagram in a Chilton or Haynes manual will be detailed enough to help find the appropriate wires or if anyone has access to a shop manual?
Old Jul 20, 2006 | 12:16 PM
congonator's Avatar
Default RE: Wiring Diagram
surprisingly, chiltons is pretty detailed
Old Jul 20, 2006 | 02:27 PM
BrunoBoy650's Avatar
i just found out which wires go to the headlight, and then wire the fog lights to those wires and electrical taped everything lol, it works
Old Jul 24, 2006 | 01:53 AM
djfrog2001's Avatar
Well, the foglights that I got have a relay so I know it won't take much voltage to activate the actual lights. What I would like to do is tap into the headlamp relay to trigger the lights however the relays in the fusebox are odd so I am not sure what wire I need to tap into. I know I can get my multimeter and try to sort it out but I was hoping one of you lads would know off the top of your head
Old Jul 24, 2006 | 02:29 AM
eclipsegs187's Avatar
I was going to say that arnt the wires already there? The only thing you sould have to do is find a stock switch to turn them on and off. I installed the fogs on my car and the good thing the wires were there dangling and i just had to plug them in. Fortunatly the car came with the stock on/off switch.
Old Jul 29, 2006 | 06:32 PM
01mitsu's Avatar
does any one have a diagram on how the headlight are supposed to be wired I bought replacement connectors and all it had was black red and white wires and the original have different colors I didnt think they would fall apart when i pulled them of the light bulb so know I am guessing as how they hook up any info would be appreciated
Thanks
djsmear
Apr 3, 2005 05:14 PM
Punisher
Mar 7, 2005 02:06 AM
aznbballa4lyf
Jan 1, 2005 03:44 PM
enrique
Nov 29, 2004 01:29 PM
Havocprez
May 5, 2004 07:54 PM
