Wont RUN!
Old Jul 8, 2003 | 02:25 AM
Puppet0's Avatar
Default Wont RUN!
<FONT face="Arial, Helvetica, sans-serif" color=black size=2>I was driving my girlfreinds eclipse cruising at about 40 mph when the engine just shut off. it didnt hesitate or sputter and had no problems previously. I think all the electrical is fine, it turns over no problem but still wont start. I think it could be the fuel pump or the ecm pump controller. If anyone has had this problem or knows what it could be please tell me any and all info, needs to be fixed soon as possible.</FONT>
Old Jul 10, 2003 | 03:10 PM
Eclipse_GSX's Avatar
Default Wont RUN!
ding dong!!! fuel problem sir...</P>
When you get too much fuel...more than running rich level...</P>
That happens...</P>
I had that problem with my high power GSX...when I didn't have recirculation kit on SSQV...running rich and when i acc. fast then that happend...</P>
Fuel problems...</P>
Old Jul 11, 2003 | 09:29 AM
Dark_angel95's Avatar
Default Wont RUN!
how would go about fixing that. just in case I get that problem?</P>
Old Jul 11, 2003 | 08:08 PM
Puppet0's Avatar
Default Wont RUN!
Actually i just got done going through the entire fuel system and its fine, then i checked for spark and there is nothin. probly should have done that first but i figured it was fuel. I replaced the distributer cap and rotor and still have no spark. any ideas?</P>
Old Jul 13, 2003 | 05:50 AM
Default Wont RUN!
maybe just a suggestion. I know honda's have it but you can try and ask. There is a relay underneath your dash, its called (main relay) it controlls most of the fuel spark function in your car . try that, cool
Old Jul 13, 2003 | 02:18 PM
Puppet0's Avatar
Default Wont RUN!
ya i took that out and tested it and its fine, its called the ECM. Ive found that the entire fuel system is ok but now there is no spark and i dont know why!
Old Jul 13, 2003 | 02:56 PM
Default Wont RUN!
have you tried your coil. I remember I had a problem for a while and it turned out to be my coil going bad.
Old Jul 14, 2003 | 02:00 AM
WHiTE GSX's Avatar
Default Wont RUN!
you replaced the distributor cap on an eclipe huh? what yr?
Old Jul 14, 2003 | 09:59 PM
Manybrews's Avatar
Default Wont RUN!
<BLOCKQUOTE>Quote: Originally posted by WHiTE GSX on 14 July 2003
<HR>
<HR>
</BLOCKQUOTE>
the 90 to 94 1.8s had a distributor.</P>
</P>
Old Jul 15, 2003 | 12:21 PM
Puppet0's Avatar
Default Wont RUN!
Have not tried the coil yet, but its next thanks. And for all those who seem to have never seen another eclipse but there own, yes some do have a distributer. Read a little about the cars before you post. I dont even own one and could tell you that.
