Wont RUN!
Old Dec 27, 2003 | 02:48 AM
alvar's Avatar
Default Wont RUN!
i had the same problem , i had to change the computer and it' runnin now.</P>
</P>
Old Dec 28, 2003 | 01:26 AM
eclipse_rider's Avatar
Default Wont RUN!
<FONT size=1>Wussup man my friend had they same problem we were goin down the road at 45 and it just cut off and it would turn over but not start come to find out his timing belt had slipped and that was the problem so check it im pretty sure that is it.</FONT>
Old Dec 28, 2003 | 01:30 PM
oldmansgs's Avatar
Default Wont RUN!
<IMG src=smileys/smiley16.gif border="0">WHat's up, no one has suggested that maybe your POWER TRANSISTOR has gone bad. This unit takes signal from your distributor and sends voltage to the ignition coil to provide spark at plugs. It can be checked with an analogue volt meter (needle type meter). If you don't have a manual with the procedure to check this out I can get the info from the factory service manual for you.
roundigo
Nov 11, 2016 12:12 PM
vpleonard
Apr 27, 2004 08:47 PM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
infinity42q
Jul 2, 2003 01:46 AM
