would you give $5300 for this??
Old Sep 18, 2007 | 09:52 PM
2bdetermined's Avatar
Default would you give $5300 for this??
I seen this on a site for a 2.0 stroker. I'd want a DOHC with 10.5:1 pistons. Tell me what you think...
Detailed Description
2.0 Litre Create Motor Long Blocks comes with the following parts installed.
Clevite 77 Rod Bearing Set
Clevite 77 Main Bearing Set
Total Seal Piston Rings
New Carter Water Pump
All gaskets and Seals
Melling Oil Pump
Eagle Specialty Forged Rods
JE Pistons in your choice of 8.6, 10.5 or 12.5 compression
16 Eaton PT Cruiser Lash Adjusters (Lifters)
16 PT Cruiser Cam Followers (Rockers)
Timing Belt
Complete Head Gasket Set
1 Pair of Crane DOHC Cams 431-0010, 431-0012, 431-0014, 431-0016 or 431-0018
1 Pair of AEM Adjustable Cam Gears
Crane Valve Springs
set of stainless steel valves
Seasoned Block and head
Blocks are bored and honed with a deck plate to insure that the cylinder walls are true.
Crankshaft and rotating assembly are race balanced
Cylinder head; Smooth the casting, and blend the seats, full race port with reshaped ports, reshaped combustion chamber, and full port matching.
Cams are degreed for proper centerline All clearances are blue printed
When ordering your short block specify SOHC or DOHC, and specify compression ratio you desire.
Long blocks are shipped without valve cover and without oil pan and no timing cover
Shipped without exhaust manifold and intake manifold
These are race engines and are sold for racing purposes only. They are sold as is, with no warranty expressed or implied. Engine contains no oil. Proper break in of engine must be observed to insure long life. Inspect all bracket mounting holes before use. Engines are built to order, estimated build time could be serveral months before engine is complete and ready to ship.
Long block with your core Long block $4699.95. Shipping cost is extra. Blocks are shipped by Motor Freight from Keyser. Lift gate service to help in unloading is available at additional cost, but must be requested at the time of order. Engine must be signed for at time of delivery.
Old Sep 18, 2007 | 10:11 PM
Default RE: would you give $5300 for this??
Why do you want 10.5:1?
I would pay that much.... but i wouldnt get those pistsons.
Is the car in your Avartar yours? I have seen that on ebay multiple times.
Old Sep 18, 2007 | 10:43 PM
Simss's Avatar
I wouldnt pay that much for it, seeing as how the 4g63 is very capable of producing a lot of horse power as it is. what are you planning on doing that requires you to get a new race engine? what kind of mods do you currently have? upgraded springs, brakes, calipers? It sure sucks when you are going fast and dont have very good means of stopping.
Old Sep 19, 2007 | 06:53 AM
Do you have a link to this. I just want to know the company. Also its not called a 2.0 stroker. That makes no sense
Old Sep 19, 2007 | 07:12 AM
Sebba, I want to get 10.5:1 because I'm keeping it N/A. And your right the avatar is from a car on ebay. My ride is basic black.
Simms, I wish my car had 4g63 but I'm one of the poor souls stuck with a 420a, and I've heard the cost for a changeover would be like $4g+ not counting the engine. Right now I'm in the process of doing a 4 wheel disk conversion and 1.5" drop respectivly.
Engineer, I got this from a site called Howell Automotive. www.howellautomotive.com . Look in the 2g eclipse section under crate engines.
Old Sep 19, 2007 | 07:26 AM
NO WAY wouldi pay that much. You dont need any of that for a n/a motor at all...
Why are you going N/A? Do you have an RS/GS?
Old Sep 19, 2007 | 07:35 AM
I got a 95 RS. Like I said just doing research. And looking for some decent imput before I commit. What I'm looking for is to get decent hp while keeping it N/A if possible. Decent being 200+ while still keeping the tires hooked up.
Old Sep 19, 2007 | 08:11 AM
sk8dudety's Avatar
if you're gettin that motor for an rs, you might as well turbo it. cause all of that stuff isnt power gaining, it's mostly just for strength... you really wouldn't notice much of a power difference when you drive it, you'd just sleep better at night knowing its a new motor... but if you're spendin that much money on a motor, you might as well turbo it and make it worth it
Old Sep 19, 2007 | 09:00 AM
Your gonna spend all that money just to be NA. Whats the point. You could build your 420a with couple extras and turbo your car for that money. And So you were gonna spend 5300 on a engine and only get like a low 15 sec to high 14 sec 1/4 mile?
Old Sep 19, 2007 | 11:21 AM
Simss's Avatar
if your serious here sell your car buy a gst or gsx and then put the left over cash into a new turbo and fuel system. it would be less of a headache and you would be much happier
